Hi, I’m planning on getting unglazed wooden window frames for our new build that I can finish, fit and glaze myself. The manufacturer has said that all windows must be CE marked to be legally supplied but a frame is not a window until it is glazed so the frames they supply will not be marked. From what I’ve read CE marks relate to the supply of windows and are not required for Building Regulations etc. My question is do I need to get these windows CE marked? I’m also building a garage and planning to make the windows myself so do these need to be CE marked?
You are correct in that simply providing the frames excludes the supplying from requiring CE marking. If you manufacture or process glass, produce insulated glass units (IGUs) or fully glazed windows – you have to make a declaration of performance and CE mark your products to show they comply with the relevant standards. However, looking at the British Woodworking Federation website, it seems that one off bespoke designs are exempt:
“There will be only a few occasions where CE marking will not be required and these will be limited to building work which is exempt from complying with the Building Regulations and then for products which are ‘bespoke’, a unique design of window or doorset, and which are supplied for inclusion in only one building project.” (http://www.bwf.org.uk/choose-wood/ce-marking-windows-and-external-doorsets-what-should-i-specify)
However, I would recommend contacting the Glass and Glazing Federation to confirm that this is indeed the case. More information can be found here: http://www.ggf.org.uk/ce-marking-faqs
Andrew Hobbs (Build It’s Digital Assistant Editor)
