Hi, I moved into a 1960s bungalow 1 year ago and it’s very cold. It has thick loft insulation and has had cavity wall insulation (previous owner). It sits on a concrete base and is detached. The windows are double glazed and are probably about 15-20 years old.
We have put extra draft excluding tapes around all windows to make a very tight seal but it is still cold up to about knee height. We have had an open fire installed and it pumps out some warmth but it’s not as hot as previous houses I have lived in. Our energy bills are way above the average and we only have it on evenings and at 19 degrees.
Does anyone have any ideas why this would be? and are there any companies out there who could help? I am aware if Homeheatseekers but they do not operate in my area and seem only to deal with loft and wall insulation. Any suggestions would be gratefully received.
Thanks
Hi Selfbuildjo,
Thanks for your question. It’s difficult to give you hard-and-fast advice without seeing the house, but there could be a number of areas worth exploring, for instance:
– The concrete floor sounds like it could be a potential culprit. Do you know if there is any insulation either below or above this?
– Even if there is insulation in the walls, ground floor and loft, it may not have been correctly installed. For example, there could be gaps in the cavity wall fill. Do you know if the previous owner had a guarantee for this which could be used to investigate and remedy any issues?
– Are there any other potential draughts at floor level; for example do you have wood floors with gaps between boards? There are products available to reduce these – but you need to be careful not to go too far in blocking out ventilation as this can lead to problems with damp etc. Take a look at https://www.self-build.co.uk/draught-proofing-your-home for more on draught proofing.
– Are the radiators and boiler correctly sized for the house? This is all about heat loss calculations and determining the right output for the boiler (kW) and radiators (BTUs). Some radiator suppliers offer online calculators that could be useful – although if you think there’s an issue a heating engineer or plumber would be your best bet.
– Is the internal air near the windows especially cold? If so it’s possible that the double glazed units aren’t as effective as they could be – perhaps they weren’t of particularly good quality and haven’t stood the test of time? This would be an expensive issue to resolve so generally I’d try to look inexpensive measures elsewhere first, if possible.
Hope these nuggets help point you in some potential areas of investigation!
Chris (Deputy Editor & Online Editor)
