Bemused over beams
I need advice on selecting and specifying simple lintels or beams. I know I would need a structural engineer’s advice for complex loads, but surely not for a simple domestic situation, such as a lintel or beam over a window or unsupported space in a single-storey building with only the roof loading above. I appreciate I can fi nd out the tile load via the tile manufacturer’s data, but how do I go on to use that to select a beam?
A quick and free solution is to get your local building merchant to ask the lintel manufacturer to schedule the lintels for you from the drawings. You will have the advantage of a priced schedule to order against. You can get schedules from different manufacturers via a different supplier in order to compare costs.
