> Questions > We have planning permission for two dwellings, but can we just build one?
19 June 2024
by Ashley Build It Wright
If permission has been granted to build two dwellings on a parcel of land, can it be used for just one dwelling? Would new permission be required for this? Thanks!
If the two dwellings are entirely separate, you can, in principle, build one and not the other. This would be on the basis that you have started, but simply not finished, the project.
You need to be careful that there are no conditions on the approval that both dwellings needed to be built together.
If the dwellings are connected in any way (a pair of semis, for example), you couldn’t really build one without fundamentally changing the design and appearance of the other, so a fresh planning application would be required in those circumstances.
If in doubt, it is always best to get formal confirmation from the council. Planning law is complicated and ever changing and there is always a possibility that the planners would find a reason to argue that both houses should have been built together.
Hi Ashley,
Thanks very much for this, Martin. I hope that asking the question of the planners doesn’t prompt them to find a reason against this…
All the best
Ashley
