Is there another name for Brick Slip or Stone Slip. I live in the US and cannot locate this material.
Hi Janice,
I think in the US this might be referred to as External Brick Veneer or Brick Veneer Siding.
Good luck!
Chris (Editor, Build It)
I think Chris is right in that it’s called brick veneer mostly, or also thin brick- I think there’s a company called zenbuild who might be able to help you over there?
Hi Janice,
Good luck!
