Is your design software based on sketchup? Also does it come with any building reg detail drawings built in?
Hi Matt,
The Build It 3D Home Designer is not based on sketchup software – it uses Arcon Evo software – which is user-friendly and perfect for those without CAD skills.
You can import building regulation drawings into your plans. Follow this link to learn how: https://www.3darchitect.co.uk/media/pdf/Building_regs_import.pdf
Hope this helps, Lucy (Build It – Digital Assistant Editor)
Hi Matt,
