Weather proofing advice for converting a timber garage
11 May 2021
by Chris Lye
We have a timber garage built from oak beams and shiplap cladding on simple stud work. It is insulated and skinned in plasterboard inside. Sat on a concrete slab but no bricks or blocks in the walls.
We are thinking about converting into a home office as a DIY project and need a couple of pointers on weather proofing the walls and adding a damp course. Is is as simple as adding a vapour membrane in on the inside of the cladding and a damp roof membrane across the floor before raising the floor on timbers to add the air gap?
  1. Jen Grimble says:
    Hi Chris,
    Thanks for your question. I’ve asked one of our experts to give an answer. In the mean time, you might be interested in this feature.
  2. Nigel Griffiths says:
    Hi Chris, Yes you’re on the right lines. Insulate the floor if you can as well – even if only between the joists. Not sure a damp course will help much if the floor structure is well above the ground level outside.
