I am considering purchasing a plot of land and, as part of the deal, I would have to relocate the driveway of the neighbouring property consisting of 150mm-thick reinforced concrete on a hardcore base. The total area is 200m². What will be the estimated cost for a contractor to build this driveway?
I would work on £22 per m² for the work you describe. This figure assumes you dispose of the excavated material on site, the road is self-draining and that no kerbs are required. If these items are needed, you should add £900 for the disposal of the excavated material and £18 per linear metre for precast concrete kerbs.
