> Questions > Is homegrown timber suitable for construction?
25 June 2026
by Archive
I’ve been told the best timber for a timber frame home should come from the Nordic regions because the trees grow more slowly and are therefore stronger. But I’m keen to use homegrown timber in my project. Is this advisable?
Homegrown timber can absolutely be used in timber frame construction, provided it has been correctly specified, strength graded and processed for the job.
There is a common belief that timber from the Northern Hemisphere is the best option because slower-grown timber is assumed to be stronger, but the reality is a little more nuanced. For structural applications, what really matters is that the timber meets the required grading and performance standards. If it has been properly assessed and manufactured for structural use, timber grown in the UK can perform just as effectively as timber sourced from overseas.
There are also some real benefits in choosing timber grown and processed in the UK. It is readily available, and supports a more reliable and resilient supply chain reducing reliance on imported materials. Shorter transport distances are another benefit, helping from an environmental perspective and contributing to a more sustainable project. It also helps support the domestic forestry and sawmilling sectors keeping more value within the UK supply chain.
From a timber frame manufacturing perspective, homegrown timber supports efficient and consistent manufacturing and delivers the levels of strength and performance required for the off-site construction of timber frame homes. So yes, homegrown timber is not only advisable, but it’s a credible and sustainable option for your self-build project.
