Get your project off the ground with our next virtual training workshop - October 21st at 7pm!
Use code BUILD for 20% offWe have a 1970 house, which has an exterior of rough cast Bradstone. We would like to change this but was told that render isn’t an option because it wouldn’t stick to the porous Bradstone. Is it possible to completely remove the Bradstone and replace it with block and render (planning accepted)? Or are there other options available to us? The Bradstone has a varied profile which would make it difficult to clad.
Hi Ginger_tom,
Altering or replacing roughcast render is a tricky business. As you’ve found, most plasterers won’t be keen to render over an existing surface, particularly if it’s been painted as they can’t guarantee the bond will be strong enough to last.
Removal can be extremely difficult, too. I suspect from what you’ve said that you’re dealing with a cement-based roughcast, which is likely to have adhered very strongly to the underlying substrate. Trying to remove it could therefore damage the face of whatever’s underneath it (eg block or brick) – ultimately causing damage that would need to be made good (ie cost you more money) before re-rendering.
One option is to try a small test panel – whereby you pick the most discrete area you can (eg at the back or side of the house) and try removing a small patch of render. This would help you to determine whether removing the roughcast across the whole property is a practical option; but obviously you will have to incur the cost of repairing the test area if removal proves impossible.
Ultimately you may have to learn to love your home with its existing finish – there’s a neat little article on the Guardian website about why it’s ok to live with pebbledash and roughcast render! http://www.theguardian.com/lifeandstyle/2010/apr/21/pebbledash-homes-nick-clegg
Chris Bates, Deputy Editor at Build It magazine
