A few examples of window manufacturers with U-values of 0.7 or lower are Internorm – many of their window and door systems achieve U-values as low as 0.6W/m²K. Norrsken’s highest performing triple glazed windows have U-values as low as 0.64W/m²K. Green Building Store also have window ranges with U-values as 0.71W/m²K (GBS-98).
When doing your own research, ensure that the U-value is for the whole window, rather than just the frame or the glazing alone. It’s also important that the windows you’re investing in are professionally installed by a qualified fitter who has experience with your chosen product. Poorly fitted windows may have gaps and cold bridges, increasing heat loss, preventing the window from performing to its full capacity.
Hi Dennis,
Thanks for your question.
Georgina Crothers (editorial assistant)
