What is the going rate for a 100mm brickwork flemish bond per m2?
Hi Nicholas,
The cost of brickwork will vary depending on which type your choose, as well as availability (and transport) in your area. However, we recommend you focus on aesthetics and products durability to make a decision.
You can see our guide to specifying bricks for your project here: https://www.self-build.co.uk/guide-specifying-bricks-your-project/
If you have a clear idea of what you are looking for, then it’s best to call a few brick companies and compare their quotes.
Sofia Delgado, assistant editor
Hi Nicholas,
